Sponsored by: CARiD
2003 Disco No Start
Old Jun 2, 2020 | 04:11 PM
dhull213's Avatar
Default 2003 Disco No Start
We have a 2003 Disco that died on an on-ramp several months ago and hasn't started since. The XYZ has been removed, cleaned and reinstalled.
Here is a list of things that have been replaced: Starter
Coil packs
Spark plugs
Crankshaft position sensor
Fuel pump
The engine turns over freely. We pulled the plug and it was sparking while cranking. There was fresh gas on the plug, so we are getting fuel.
We are stumped. Any suggestions?
Old Jun 11, 2020 | 10:13 AM
Art H's Avatar
Sounds like timing. How is the chain and camshaft? I doubt the 4.6 is an interference engine, but if the timing chain jumped a tooth or something happened to the timing, it would explain why you have a no start. You have fuel, air, and spark, just have to make sure they are all happening at the right time.
Old Jun 11, 2020 | 10:18 AM
Sixpack577's Avatar
Correct that the 4.0/4.6 are Not interference engines.
Old Jun 11, 2020 | 10:19 AM
Sixpack577's Avatar
Check for codes, that can help point you in the right direction.
Old Jun 11, 2020 | 10:24 AM
Art H's Avatar
Absolutely, Codes are not just there to make you fail inspection: They are a useful tool to see inside your engine to find out what is ailing it.
notgivingup2018
Dec 12, 2018 06:20 PM
Barbara Daca
Jul 11, 2018 05:29 AM
GROVERDISCO
Dec 14, 2012 01:54 PM
mdanger88
Jun 10, 2011 11:51 PM
sledmaker
Jul 31, 2006 09:54 PM
