Sponsored by: CARiD
2004 Disco Tranny/Transfer case
Old May 28, 2014 | 06:26 PM
Euman8's Avatar
Default 2004 Disco Tranny/Transfer case
I have an '04 disco and developed a grinding type noise that I think is coming from the transfer case. in the small transfer case gear shifter it is slightly detectible. I removed the front drive shaft and I dont hear the grinding any more. Makes me wonder if it is the transfer case at all? may be the front differential? No way to just put it into just 2 wheel drive (rear drive) that I can tell. Thoughts anyone?
Old May 28, 2014 | 08:29 PM
jhmover's Avatar
On an 04 you can lock the center differential then you can drive it with one driveshaft. Take the high-low lever move it into neutral then pull it to the left and back into high. Don't forget to put it back to unlocked when you put the front driveshaft back in.
smokinwheels
Dec 28, 2010 09:09 PM
yonniecarrizo
Dec 30, 2008 06:06 PM
Chillbred
May 7, 2008 06:39 AM
DerrickInMississippi
Jan 12, 2008 07:49 AM
m1943
Aug 6, 2007 05:56 PM
