Sponsored by: CARiD
3 amigos with front driveshaft out question
Old Feb 26, 2013 | 08:59 PM
robersonb's Avatar
Default 3 amigos with front driveshaft out question
Does the 3 amigos constantly beep when the front drive shaft is out or do I have another issue?
Old Feb 26, 2013 | 09:43 PM
You have another issue, they have no idea the front propshaft is missing.
Old Feb 26, 2013 | 10:22 PM
robersonb's Avatar
o.k. so the link has a picture of my lights flashing. The dings ring with the blinking of the two gears with the x on them in the left top corner. Took it for a test drive around the block after bleeding system and the dinging never stopped.
Old Feb 26, 2013 | 10:23 PM
robersonb's Avatar
By the way this is with the engine not running before anyone freaks about my oil light.
Old Feb 27, 2013 | 12:21 PM
robersonb's Avatar
Default lights on propshaft out
I thought Mike said that the three amigos would be on while propshaft was out and would go away when you plug it back in
However, my primary question is what the two gears with the x is referring too.
Old Feb 27, 2013 | 07:09 PM
I believe that is a transmission fault.
Old Feb 28, 2013 | 04:59 PM
robersonb's Avatar
woohoo, simple fix the transmission had been knocked a little out, back to normal with check engine only light with an ultra guage on its way to help with that
Old Feb 28, 2013 | 05:09 PM
jafir's Avatar
99-02 will set the amigos on if you turn the key on with the diff locked. If you lock it after you start the car everything is fine.
robert.juric
Nov 3, 2022 06:08 PM
FlyingZebra34
Dec 16, 2013 03:38 PM
dr. mordo
Sep 30, 2012 11:25 PM
alpineclimber
Jan 31, 2010 04:56 PM
ljdiscovery
Aug 21, 2009 10:41 AM
