Sponsored by: CARiD
'95 Discovery starter issue
Old Feb 26, 2012 | 12:20 PM
L.W.'s Avatar
3rd Gear
Default '95 Discovery starter issue
Would appreciate any insight the forum might offer for the following:
Three days ago, upon ignition got just "click" and no start. Battery tested strong (it's 4 months old). Ran a direct connection from battery to starter which spun but failed to engage. Replaced starter (and solenoid). Vehicle cranked right up. Drove 140 miles with intermittent stops and starts - no problems. Went to start vehicle today (4th day with new starter) and again, just "click" and no start. The new starter installed has a lifetime warranty but need to know if there's a bigger issue I'm not aware of. Thanks again for any helpful advice.
L.W. in Florida
Old Feb 26, 2012 | 01:06 PM
Check for corrosion on the battery cables, it is common for them to corrode because of age and this can cause a no start issue.
If they are to corroded look into replacing them, Antichrist sells a nice kit, he is a forum member.
Old Feb 26, 2012 | 03:10 PM
L.W.'s Avatar
3rd Gear
Default re battery cables
battery and cables are in good shape, clean, tight, charged, etc. As said, new starter worked upon installation...won't work 2 days later...Any possibility there's a fuse being blown, or some sensor associated with ignition? Don't want to approach repair until I have a fairly good idea of problem source. Best case is DIY for me.
Old Feb 26, 2012 | 03:34 PM
ptschram's Avatar
Pull the smaller of the two wires, attach test light, turn key. Does light illuminate???
Old Feb 27, 2012 | 01:57 PM
L.W.'s Avatar
3rd Gear
Thinking it may be a flukey ignition switch
Old Feb 28, 2012 | 03:52 AM
antichrist's Avatar
So you're saying there's no power to the small wire going to the starter solenoid?
Gimebakmybulits
Jul 14, 2014 05:57 PM
S_Cash
Feb 25, 2014 12:45 AM
mole1066
Oct 18, 2012 02:08 AM
johnkbl
Apr 23, 2012 07:49 PM
Buzzwalburg
Jan 2, 2012 07:55 PM
