Sponsored by: CARiD
97 Discovery Oil Pressure Problem
Old Aug 17, 2013 | 09:23 AM
Kevin L.'s Avatar
8th Gear
Will do that on the next oil change. Thanks for the info. Is that a good filter? I asked for a higher end filter.
Old Aug 17, 2013 | 09:40 AM
Purolator L40316, WIX 51515 or 51773 are some. I tend to like the jumbo filter which adds more oil capacity. FRAM is all cardboard and promotional budget. Some run the really expensive filters, which is OK, if you don't try to extend the drain interval. Stay at 3,000 - 5,000.
Oil and filters should be done early and often, like voting in Chicago.
Here is a pix of two engines, both in the 185 - 190K range, one on a diet of Rotella or Castrol at 3,000 - 5,000 intervals. And mine that was not under previous ownership. Even use of a variety of snake oils and Rotella over two years was not enough to get rid of the gunk. I tried BG, Marvel Mystery Oil, ATF, GUNK.... so I must conclude that it would have looked a whole lot worse.
Attached Thumbnails 97 Discovery Oil Pressure Problem-100_0313.jpg   97 Discovery Oil Pressure Problem-p1050979.jpg
Old Aug 17, 2013 | 09:51 AM
Kevin L.'s Avatar
8th Gear
Is the WIX filter good enough or should we be using something else? I'll Check out a reader at the local parts store today.
Old Aug 17, 2013 | 09:31 PM
WIX is a quality filter.
sideshow
Oct 27, 2013 08:38 PM
eaglewing
Apr 16, 2011 11:06 AM
smokey73
Mar 9, 2010 09:14 PM
DooDer
Jan 12, 2010 10:46 PM
Spyder7892
Mar 3, 2009 08:57 PM
