Sponsored by: CARiD
98 Discover I Headlights Will NOT Turn On
Old 01-13-2014 | 01:09 PM
dr6mccullough's Avatar
4th Gear
Default 98 Discover I Headlights Will NOT Turn On
About 2 years ago our light switch overheated and melted and therefor we could not turn on the lights. We replaced the switch and it solved the problem. Now, we have a new problem and the headlights will not turn on at all (low or High). The switch is still working but we replaced the bulbs and the fuses and its still not working. The parking lights, break lights, and blinkers work, just not the head lights. Anyone have any other suggesstions on what it might be and how easy it is to fix ourselves?
Thank you for any advice/suggesstion!
dr6mccullough
Old 01-13-2014 | 01:31 PM
abran's Avatar
I'm guessing that your switch needs to be rebuilt.
I did a write up on it attached. Super easy.
https://landroverforums.com/forum/sh...954#post431954
Old 01-13-2014 | 09:05 PM
4th Gear
Thank you Abran. We will try that route again but we recently replaced the switch??
Old 01-13-2014 | 09:26 PM
abran's Avatar
If you replaced with a used switch they are notorious for the contacts getting gunked up/corroded.
The grease the factory used turns hard and actually stops conducting.
It takes 15-30 mins max. Not hard to do
Old 01-14-2014 | 11:37 AM
4th Gear
Thank you! We are trying this weekend and let you know if it is successful!
dr6mccullough
01-31-2014 02:10 PM
EstorilM
02-21-2010 10:36 PM
Street Wolf
09-27-2008 09:58 AM
95Discovery
06-20-2006 03:56 PM
Quick Reply: 98 Discover I Headlights Will NOT Turn On
