Sponsored by: CARiD
98 Discover I Headlights Will NOT Turn On
Old Jan 13, 2014 | 12:09 PM
dr6mccullough's Avatar
4th Gear
Default 98 Discover I Headlights Will NOT Turn On
About 2 years ago our light switch overheated and melted and therefor we could not turn on the lights. We replaced the switch and it solved the problem. Now, we have a new problem and the headlights will not turn on at all (low or High). The switch is still working but we replaced the bulbs and the fuses and its still not working. The parking lights, break lights, and blinkers work, just not the head lights. Anyone have any other suggesstions on what it might be and how easy it is to fix ourselves?
Thank you for any advice/suggesstion!
dr6mccullough
Old Jan 13, 2014 | 12:31 PM
abran's Avatar
I'm guessing that your switch needs to be rebuilt.
I did a write up on it attached. Super easy.
https://landroverforums.com/forum/sh...954#post431954
Old Jan 13, 2014 | 08:05 PM
4th Gear
Thank you Abran. We will try that route again but we recently replaced the switch??
Old Jan 13, 2014 | 08:26 PM
abran's Avatar
If you replaced with a used switch they are notorious for the contacts getting gunked up/corroded.
The grease the factory used turns hard and actually stops conducting.
It takes 15-30 mins max. Not hard to do
Old Jan 14, 2014 | 10:37 AM
4th Gear
Thank you! We are trying this weekend and let you know if it is successful!
dr6mccullough
Jan 31, 2014 01:10 PM
Steellifter
Mar 24, 2012 01:38 PM
EstorilM
Feb 21, 2010 09:36 PM
Street Wolf
Sep 27, 2008 08:58 AM
95Discovery
Jun 20, 2006 02:56 PM
