Sponsored by: CARiD
ABS lights on
Old Mar 12, 2012 | 06:42 AM
JLandy's Avatar
Unhappy ABS lights on
Hey people can you help me, i have a Land Rover TD5 (2000) i have 3 lights on permanently on the dash, (TC/ABS/Incline) i had it tested and the diagnostics said it was the ABS sensor so i had it replaced by tried and trusted techs that i have known a long time. The lights remain on so we are at a loss, any ideas please?
Old Mar 12, 2012 | 06:48 AM
Search this forum for the Three Amigos. An all to common problem for Discovery 2 vehicles.
Old Mar 12, 2012 | 06:15 PM
Yup, the 3 Amigo's, could be almost anything.
Old Mar 12, 2012 | 06:43 PM
Would help to know where you are located and how you read the codes? If you guessed right and made a fix, you must use a scanner to clear the codes.
Old Mar 15, 2012 | 03:58 PM
JLandy's Avatar
I am in little old England. Thanks for reply, the sensor they took off was broken so we guessed it would all be hunky dorey but those wee little lights still remain.
Old Mar 15, 2012 | 04:17 PM
A regular basic OBDII scanner won't do it, you need a more advanced model, try stealership, or shop that does a lot of work on newer Rovers. Ask if they can reset the codes for the ABS system.
Alan Phillips
Nov 19, 2018 03:27 PM
TopGun
Sep 1, 2014 01:11 PM
cottonpatchweims
Feb 10, 2005 07:18 PM
cottonpatchweims
Jan 14, 2005 01:59 AM
