Sponsored by: CARiD
ABS MODULATOR ELECTRICAL FAULT REPAIR ( 3 amigos)
Old Sep 12, 2013 | 08:02 AM
aftermath431's Avatar
Default ABS MODULATOR ELECTRICAL FAULT REPAIR ( 3 amigos)
Hi I'm new to Land rover and need some help. I have a 2000 disco II. I would like to know if this will fix the problem and tracking control (not sure the name of it but the ones with the 3 amigos lights). Our will this just cancel out the light ? also with the 3 amigo lights on does the all wheel drive our 4 wheel drive still? work again not sure what ones its called. Here is the URL to the repair - ABS Mod - LAND ROVER CLUB V.I.
Old Sep 12, 2013 | 08:12 AM
With a Disco, you can not electrically turn off 4WD. It is always 4WD. You can select high and low speed range, and if equipped, can also lock CDL lever to put 50% power front and rear. The three amigos impact other performance features that are controlled by various computers hidden inside the truck.
You found a good reference to the repairs. Also, if you would like a copy of the factory shop, electrical, and owner manuals they are called the RAVE, and are a free download below.
Also inspect your front drive shaft for being upgraded to greaseable on the double joint. If not, it can snap without warning, and bash hole in transmission. And keep in mind that the factory heat gauge will point at 50% until you are past overheating. A scanner will show the true temp, not "normal" for 130-240F.
Old Sep 12, 2013 | 12:37 PM
So, how mechanical are you. As Buzz mentioned you can not turn it off and yes you will not have the traction you normally would have with the lights off.
If you want some help, send me your number and I'll be glad to walk you thru what needs to be done.
Old Sep 14, 2013 | 06:06 AM
Default thanks
Thank you guts for the help I'mgoing to try and find and do the repair today.
Old Sep 16, 2013 | 06:23 PM
jalodge's Avatar
Does this fix the problem so all features work properly or just turn off the lights?
Old Sep 17, 2013 | 04:41 AM
Default 3 amigos
Thanks guys for the help.I'm going to try fix the problem today. Disco Mike that would be great.[/QUOTE]
jycsalas
Jan 8, 2025 07:38 PM
azoverlander
Mar 12, 2011 02:16 PM
pilsner
Dec 2, 2008 10:06 AM
Willie 00D2
Sep 12, 2008 06:35 PM
