Sponsored by: CARiD
ABS Pump
Old May 8, 2007 | 02:05 PM
dallasrr's Avatar
4th Gear
Default ABS Pump
Does anyone know where to have an ABS pump rebuilt?
TIA
Old May 8, 2007 | 03:01 PM
Default RE: ABS Pump
You don't rebuild them.
What year is your truck, what model and mileage??
What is wrong with yours?
Mike
Old May 8, 2007 | 03:02 PM
dallasrr's Avatar
4th Gear
Mike thanks for the fast response.I have a 90’ Range Rover with 179K mi.
There is no pressure out of the pump only a trickle of fluid.
This all started when I started feeling vibration when braking. I put the truck on a lift to see what was going on. I notice that the front passenger side didn’t stop when the others stopped. So I then changed out the front rotors and calipers. (I assumed that the extra braking/heat on the driver side warped the rotor and that was the vibration I was feeling) bleeding the brakes is when I came across the issue with pump.
dammad
Jan 26, 2009 01:50 PM
barranr
Jun 3, 2007 06:36 AM
cottonpatchweims
Feb 10, 2005 07:18 PM
cottonpatchweims
Jan 14, 2005 01:59 AM
