Sponsored by: CARiD
ABS troubles i think
Old Oct 17, 2007 | 08:16 PM
dave1070's Avatar
8th Gear
Default ABS troubles i think
Ok so here is the problem between about 20 to 35 mph my abs starts cutting in for no reason, it does it a lot but not all the time, also it started this a few months ago and i replaced wore front pads and it was fine for awhile. checked the pads their ok front and rear. also if you stay on the brakesthe abs it cuts back off below twenty. is this a sensor??? or is it something else.
Old Oct 17, 2007 | 09:42 PM
ajh's Avatar
ajh
Default RE: ABS troubles i think
You mean the traction control? That would mean not all your wheels are turning at the same rate for some reason. If you drive in a tight circle do you get odd behaviour?
Old Oct 17, 2007 | 11:25 PM
dave1070's Avatar
8th Gear
no it is only under braking and i feel it in the pedal.
Old Oct 18, 2007 | 10:24 AM
ajh's Avatar
ajh
I would check all 4 wheels, pads, and caliper pistons, sounds like you've got siezed calipers.
Old Oct 18, 2007 | 10:37 AM
Short and sweet, you have an issues that only your ECU can answer. Find a small shop, not a dealer, that read the codes, write them down and ask to have them cleared to see if they will come back.
lipadj46
Aug 19, 2009 06:11 PM
dave1070
May 16, 2007 09:39 AM
Sean 1313
Jan 13, 2006 06:25 AM
oberdahill
Sep 10, 2005 11:17 PM
Dave_Liverpool
Jun 22, 2005 11:29 AM
