ABS troubles i think
Ok so here is the problem between about 20 to 35 mph my abs starts cutting in for no reason, it does it a lot but not all the time, also it started this a few months ago and i replaced wore front pads and it was fine for awhile. checked the pads their ok front and rear. also if you stay on the brakesthe abs it cuts back off below twenty. is this a sensor??? or is it something else.
Short and sweet, you have an issues that only your ECU can answer. Find a small shop, not a dealer, that read the codes, write them down and ask to have them cleared to see if they will come back.
