Sponsored by: CARiD
Airbag light
Old Oct 4, 2007 | 02:19 PM
hendoc3's Avatar
Default Airbag light
I keep my1997 Kia Sportage around to drive to work because its good on gas. The airbag light has been on for sometime now but the airbag has never deployed. Of course my luck Virginia passed a new law this year that they cannot pass a safety inspection with the airbag light on. Anyone have any ideas how to get an airbag light off?
Old Oct 4, 2007 | 02:30 PM
Default RE: Airbag light
You have to find a shop with the proper scanner to go into the ECU, find the problem, repair it and clear the code, just like a Rover.
If you are lucky, it will be a low voltage issue, have you replaced or unhooked the battery prior to the light coming on?
Old Oct 4, 2007 | 04:02 PM
hendoc3's Avatar
I did replace my battery last year
Old Oct 4, 2007 | 05:11 PM
That could have caused it.
Old Oct 9, 2007 | 09:10 AM
hendoc3's Avatar
disconnecting the battery didnt work. I guess to the dealer i go.
Old Oct 9, 2007 | 09:14 AM
Disconnecting the battery will cause the problem, not cure it. Very little if any of the Rover problems will be solved by cutting the current.
mike031
14
Nov 2, 2018 10:41 PM
mbreneisen
LR2
Nov 5, 2010 09:39 AM
demonlarry
Mar 8, 2010 01:11 PM
faversham
Jan 28, 2010 04:59 PM
NATEDOGG
Oct 14, 2009 03:27 PM
