Sponsored by: CARiD
battery flat - totally locked out - how to open bonnet? other solution?
Old Nov 22, 2016 | 05:01 AM
landi's Avatar
4th Gear
Default battery flat - totally locked out - how to open bonnet? other solution?
I am totally locked out - yes, I do not have the "safety key" only two electronic keys...I need to open the bonnet/ hood I guess to get some live to my battery again. Normally the battery used to have minimal power to unlock the doors but today it is totally flat.
1) Could I remove the front grill (without too much damage)?
I pulled... and the lower part moved out...but the upper part seems to be screwed in somewhere, correct?
2) Is there a way to reach the wire through the grill, pull and unlock?
3) more suggestions...
Thanks a lot!
Help needed really.
Landi
Attached Thumbnails battery flat - totally locked out - how to open bonnet? other solution?-img_9602.jpg
Old Nov 22, 2016 | 05:24 PM
abran's Avatar
Sorry to be redundant, but you are sure there is no key blade in your remote? You have opened both up?
Posting in the LR4 section will get you more responses.
Old Nov 23, 2016 | 03:22 AM
landi's Avatar
4th Gear
no, unfortunately they are both gone...
thanks,
landi
Old Nov 23, 2016 | 09:11 AM
abran's Avatar
thanks,
landi
Call the closest Land Rover dealer. If you send them a picture of your drivers license and either registration or title of ownership, they can order you a new key blade via your VIN.
I just did this for a customers LR3, it was around $70. If you are having problems I can order one for you.
it took about 5 days, for $20-$30 extra rush fee you can get it in 2 days.
Quinn519
Jan 23, 2022 09:44 AM
landi
Nov 30, 2016 05:31 AM
rossmacwillson
Jul 19, 2014 06:54 PM
DiscoDoobie
Feb 10, 2011 10:10 AM
