Sponsored by: CARiD
Bolt and torch
Old Dec 30, 2012 | 12:58 PM
nicksims's Avatar
7th Gear
Default Bolt and torch
Replacing the started on my '01 Disco II. Except getting the 2 8mm bolts out is just not happening. Tried soaking with wd-40 (I hear I should go get some PB Blaster). No luck. I'd like to try a torch. I have a small torch and can get in there without hitting anything else. But... how long do you hold the torch to the bolt head and the surrounding area without overheating the bolt head? I don't want to be that knucklehead and strip the bolt head if I overheat it.
Thanks for the help.
Old Dec 30, 2012 | 09:26 PM
It helps to wash out the allen head bolts (brake parts cleaner) so the socket and six extensions can be shoved all the way in there, working from front of axle. PB Blaster is the fluid of choice. May have to soak overnight.
Old Jan 6, 2013 | 09:32 PM
nicksims's Avatar
7th Gear
Finally finished! I did get and use plenty of PB. And it soaked overnight, more heat, more PB, more yelling, etc...
Thanks.
focusontheworld
Oct 21, 2012 01:00 AM
ChefGabe
Dec 29, 2011 09:44 AM
EstorilM
Sep 21, 2011 09:31 AM
Lchop1.8T
Sep 19, 2011 03:00 PM
adigerol77
Jul 30, 2011 03:36 PM
