Sponsored by: CARiD
Brake issues
Old Aug 3, 2017 | 09:14 AM
Gardenia's Avatar
Default Brake issues
Can anyone help? I have put in a new master cylinder, new calipers, brake pads, brake line and I still don't have brakes. Can anyone help? 1997 landrover.
Old Aug 3, 2017 | 09:29 AM
OverRover's Avatar
Check for any brake fluid leaks first! But it sounds like you still have air in the system, so bleed it again. The info above is from the LR RAVE Manual, and there are videos on Ytube for the DI. Good Luck!
Old Aug 3, 2017 | 09:44 AM
Gardenia's Avatar
okay, great! thanks! I will have this done before thinking about purchasing a booster?
Old Aug 3, 2017 | 02:01 PM
DiscoCam's Avatar
Had the same problem. Ended up being the new master cylinder. It was also defective.
Make sure to use a genuine Land Rover master cylinder
Old Aug 3, 2017 | 02:04 PM
Sixpack577's Avatar
Your other post said your brakes were "hissing".
Which sounds like an air leak, and why you have no brakes. Have someone pump the pedal while you look for leaks. Start in obvious places, the MC, each caliper, and every rubber line. Bubbles and fluid should be easy to see.
Old Aug 3, 2017 | 06:19 PM
Gardenia's Avatar
Found the air leak, coming from the booster, have a poor seal around booster. used silicon to seal and now I have brakes.
Alex Spencer
Apr 20, 2017 07:48 AM
lonely king
Jun 21, 2008 12:18 PM
bavarian_range89
Dec 29, 2007 02:56 AM
97XD
Jun 1, 2007 12:17 PM
richo888
May 12, 2005 11:50 PM
