Sponsored by: CARiD
brake rotor replacement
Old Oct 14, 2007 | 01:45 PM
lightfootboyd's Avatar
4wd High
Default brake rotor replacement
I am trying to find out any thing I can on what tools I need to replace my rotor, 1996 Disco. There is a large hex nut on the spline and I cant find the right size socket?
Help
Old Oct 15, 2007 | 01:37 PM
Adz's Avatar
Adz
Default RE: brake rotor replacement
If you mean the front wheel bearing / hub locknut and retaining nut - they're 52mm. Best to use a box spanner rather than a socket - the inner one isn't torqued up and you'll have difficulty finding a socket deep enough to get to it over the spline. Only the locknut needs to be torqued up - I've never bothered with the ones on my Defender - tight enough is accurate enough. Make sure you use a new locking washer, if that fails you can wreck the bearing and hub in short order.
Cheers,
Old Oct 16, 2007 | 04:40 AM
Pierre's Avatar
Tab washer (lock washer) P/NFTC3179.
HTH
Pete
grrRover
Feb 18, 2014 11:41 PM
antichrist
Apr 4, 2011 02:43 PM
mcrw
Aug 16, 2010 09:00 PM
mr_arrowhead
Jan 3, 2008 11:42 AM
hooman
Dec 16, 2007 10:19 PM
