Sponsored by: CARiD
Brake Warning Light "Check Brake Pads"
Old Mar 9, 2010 | 09:19 PM
Florida04RR's Avatar
Default Brake Warning Light "Check Brake Pads"
The Brake light came on, and the message "Check brake pads" appeared. I replaced my front pads, so now all the pads are new. Now the hard part...how do i turn off the light? do i need an ABS scanner? can i use some type of voodoo chant and turn the key to the 'on' position 5 times?
thanks,
chris
Old Mar 10, 2010 | 06:09 AM
Rovin4life's Avatar
did you replace the sensors as well. if you did then turn the key on position one or two and leave it on for five minutes.
cipher982
Nov 9, 2019 11:22 AM
FlyingZebra34
Feb 22, 2014 05:39 PM
filind1014
Sep 21, 2009 11:04 AM
ljdiscovery
Jan 17, 2009 01:35 PM
antichrist
Sep 6, 2007 06:19 AM
