Sponsored by: CARiD
Brakes/Rotors/Sensors
Old May 22, 2007 | 08:22 AM
  #21
sysroute's Avatar
Default RE: Brakes/Rotors/Sensors
I don't have an impact driver... Should I stick with a mechanic? Can any brake place handle this job or should I seek someone that specializes in rovers?
Old May 22, 2007 | 09:29 AM
  #22
If you want to save some BIG $$$'s then let us help you order the right parts and walk you thru installing them, it really is easy.
Mike
Old Aug 12, 2007 | 03:15 PM
  #23
DonB's Avatar
I too am starting a rear brake job. I had a squealing noise when driving that went away when the brakes were applied. I have done a bunch of brake jobs but mainly Fords and Jeeps. I pulled the wheels and the calipers off (so far almost twins to the Ford Explorer and Grand Cherokee. I couldn't figure how the rotors were retained. By the way I have a 2000 Discovery II. In the last post I noticed it says that there's a #4 screw. If I remove this screw will this let the rotor come off? (Only one screw?) Also is there somewhere that I can get technical manuals or at least a blow up drawing of what I'm working on?
Thanks,
DonB
Old Aug 12, 2007 | 05:15 PM
  #24
Pull the #4 phillips and the rotor will come off his the hit from a hammer.
As for the manual, you can down load rave CD's for free on line or buy them on E-Bay for about $10.
Don't forget to use some sound deadening material on the backs of the brake pads and flush all the old brake fluid out.
Old Sep 2, 2007 | 12:27 AM
  #25
wardolb's Avatar
the brake light will come on when the pads are low...there isa sensor
Old Sep 2, 2007 | 09:52 AM
  #26
ORIGINAL: wardolb
the brake light will come on when the pads are low...there is a sensor
Not on all Rovers, Disco's don't have wear sensors.
bcolins
Sep 14, 2015 01:10 PM
FightOnUSC79
Nov 26, 2010 09:43 AM
LR3invancouver
Oct 4, 2007 06:43 PM
BuffaloRider
Oct 23, 2006 01:17 PM
MoMotta
Sep 28, 2005 02:22 AM
