Sponsored by: CARiD
cant get it into low range
Old Aug 27, 2005 | 05:29 PM
adowgiert's Avatar
Default RE: cant get it into low range
Bene-
Did you have any luck freeing the linkage. I' having similar problems, only I can't get the TC in to lock or low range. Haven't had a chance to lube yet. Just wondering if you were successful.
Old Aug 28, 2005 | 02:19 AM
Bait's Avatar
Actually, I gave Bene some bad advise. He can move the transfer box lever from lock to unlock. He can't move the lever from low to high range.
For obvious safety reasons, the vehicle must be in neutral to change ranges. First, with a test light, key on, and in neutral. Check for power on both sides of fuses F12 & F13. Located on the drivers side under dash panel. This may seem simple but it tells a lot.
We'll go from there.
Old Aug 30, 2005 | 03:35 PM
JRdisco1's Avatar
before I got my car I was told this was a problem. The guy said that if I ever got one I should put in in 4L once a month just to keep it from seizing up. I also turn on the heater about once a month even in summer just to keep things on the up and up... my linkage is only 8 years old
Old Aug 30, 2005 | 09:39 PM
adowgiert's Avatar
Yeah, I seriously doubt that mine has ever been put in to lock or low range. Once it's freed, I'm gonna be dilligent about putting it in monthly.
sideshow
Mar 8, 2015 12:30 PM
KlamathMatt
Dec 1, 2013 03:59 AM
DROVER1984
Dec 12, 2012 09:29 AM
tadjo
Feb 4, 2011 06:03 PM
