Sponsored by: CARiD
Carb piece?
Old Jan 26, 2018 | 01:21 PM
Meldav32's Avatar
Default Carb piece?
Can I buy this piece separate? I did some research and I think it’s the heating plate to the throttle body? It’s leaking coolant and getting into the motor and smoking out from under the hood. Just one more problem I found while trying to figure out what the issue is w my disco II. Limp mode and voltage issues due to positive battery cable. Any help is appreciated
Old Jan 26, 2018 | 01:29 PM
mollusc's Avatar
The piece itself is not the problem unless it's cracked or otherwise damaged. New gaskets and/or hose will fix it.
There are many threads on this forum about the throttle body heater. Some people bypass it entirely. The arguments for and against are discussed in detail in all of those other threads.
Old Jan 26, 2018 | 03:16 PM
Meldav32's Avatar
WELL I need to find these threads bc I’m thinking the same thing. I did however order replacement gasket on eBay for $26 which is way better than anything local.
Old Jan 26, 2018 | 03:36 PM
OverRover's Avatar
I hope bought this (plate & gasket) > https://www.ebay.com/itm/LAND-ROVER-...xXIZir&vxp=mtr
Old Jan 26, 2018 | 04:16 PM
Meldav32's Avatar
Over Rover~ yes that’s the one expect I paid $25.95 or something but exact pic etc.
Old Jan 26, 2018 | 04:20 PM
OverRover's Avatar
That's cool, I was just hoping you didn't get only a gasket for $26.
Old Jan 27, 2018 | 02:00 PM
Paul Grant's Avatar
If cost were no object or you really suffered from obsessive tendencies, there's always this by Falconwerks:
Throttle Body Heater plate, bronze upgrade, V8 Discovery & P38a
Old Feb 14, 2018 | 10:26 PM
Meldav32's Avatar
thank you for the info! That is a huge price difference but seems to will last much longer
jdogg
Jan 27, 2013 05:46 PM
Savannah Buzz
Apr 15, 2012 02:17 PM
Classic1991
Aug 19, 2011 12:54 PM
kcirtap
Oct 12, 2007 08:32 AM
greenoval
May 11, 2006 11:45 AM
