Sponsored by: CARiD
cb help please!!!!
Old Nov 27, 2006 | 09:23 AM
mussells's Avatar
6th Gear
Default cb help please!!!!
my cb in my landy gets terrible interference,im getting 5 pound with engine on and its worse if i switch lights or wipers on. has anyone had this problem and how do i fix it????
Old Nov 27, 2006 | 11:52 AM
Default RE: cb help please!!!!
You need to start checking and cleaning your grounds and connections.
Where did you hook in for the CB's power?
Mike
Old Nov 28, 2006 | 09:14 AM
mussells's Avatar
6th Gear
STRAIGHT TO THE BATTERY UNDER THE SEAT(EARTH AS WELL) AIREL IS ON NUDGE BAR DIRECT TO CHASSY
Old Nov 28, 2006 | 11:00 AM
Sounds like it is time to stop by your CB shop and get some feed back from them.
Mike
Old Nov 28, 2006 | 05:24 PM
Adz's Avatar
Adz
I'm a long way from being an auto electrician, but one thing you could try:
If you've wired the CB earth back to the battery earth, the cable might act like an intereference ariel - try earthing the unit to the body/chassis very close to the unit instead of running a cable to the battery. Nice thing is - this should take you about 2 minutes tops ;-)
Cheers,
Old Nov 29, 2006 | 10:50 AM
mussells's Avatar
6th Gear
nice job i,ll try that. cheers
Paul Aspen
Nov 4, 2013 02:10 PM
tarpon66
Jul 27, 2011 12:38 PM
sawadeh
Jul 2, 2011 08:10 PM
Speed racer
Oct 11, 2008 10:56 PM
