Sponsored by: CARiD
Clean & Prep.
Old Oct 11, 2015 | 12:04 AM
Green_Oval's Avatar
Default Clean & Prep.
Hey guys on my previous thread I stated I was doing heads on my disco..
I would like if someone could help give me a straight forward answer on how to clean the mating surfaces of the heads. Through research I've found that it is a bad idea to use abrasives but I'm also being told I can use 4 ott steal wool on the surfaces..
Also the owner before me WELDED The brush guard on.. is there anyway to get the radiator out without pulling the front end apart?
Any help would be appreciated.
Gage
Old Oct 11, 2015 | 12:12 PM
partsguru's Avatar
3M makes an abrasive-impregnated rubber bristle brush that GM recommended for their aluminum blocks, 3M 07527. Russ
Old Oct 11, 2015 | 01:03 PM
abran's Avatar
I use WD40, a rag, and some elbow grease to remove any debris. Then hit the surfaces with a knife sharpening/honing stone. Use the fine side. If there are any uneven surfaces you will see based on the differences in sheen. Keep working until the finish is uniform.
For piston tops I use the green 3m Roloc plastic adhesive pads on a drill.
Old Oct 11, 2015 | 02:11 PM
Green_Oval's Avatar
Where can I get that? An auto parts store? Also what grade do I need as far as abrasiveness
Joshman
Sep 25, 2012 07:28 PM
echomike
Mar 4, 2011 07:00 PM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
r1dad
Dec 22, 2005 09:46 PM
