Sponsored by: CARiD
Cleaning Engine
Old May 12, 2008 | 01:24 PM
roving patrol's Avatar
Default Cleaning Engine
Dear Gents,
I am thinking about cleaning my Engine ( top to the bottom ) with an Engine Degreaser this weekend. Before I do so, what extra precautions should I take besides covering the electrical wirings?Just a little advice from the pros, pls!
Old May 12, 2008 | 01:40 PM
bhorwhat's Avatar
Default RE: Cleaning Engine
Here's some tips I've had luck with.
1. Do this yourself at your house, not at a car wash with a high pressure wand. The pressure can so great it can dislodge electric connections.
2. Warm engine - not hot. Turn off engine and apply product. Expect to use at least two or three cans of 'Gunk' or 'Engine Bright'. Allow to soak for about 10 minutes before hosing. Restart engine just before hosing down.
3. Cover master cylinder with a plastic bag. Do same with distributor or electronic ignition module. Be careful not to direct water on these areas. If the master cylinder area needs cleaned, better to do so with a rag.
4. Do this in your yard if the vehicle is particularly greasy. It will make a mess of your driveway.
Old May 12, 2008 | 03:14 PM
What year and model are you thinking about cleaning???????????????????????
This does make a difference.
Old May 12, 2008 | 03:22 PM
Hi DiscoMike,
It's a 97 Discovery!
Thanks
fri3daz3
Oct 22, 2008 01:11 AM
mellyagaunce
Oct 8, 2008 07:55 AM
jkid
Oct 12, 2007 06:55 PM
xadamx
Jun 15, 2007 09:16 AM
Rustysrf89
Oct 30, 2005 09:28 AM
