Sponsored by: CARiD
clunk in front end
Old Sep 14, 2015 | 08:05 AM
deb1's Avatar
5th Gear
Default clunk in front end
I have a 05 LR3 and when I hit a bump such as a railroad crossing it has a audible clunk coming from the front end. I am a alignment shop and have inspected the front end for loose parts and found none. Do the air springs on these make noise when you go over a considerable bump? thanks, don
Old Sep 14, 2015 | 10:07 PM
lordmorpheus's Avatar
Most likely the control arm bushings. Common failure point on both the LR3 and LR4. I would check these carefully. The last 3 vehicles I've worked on, or had worked on in a shop I used to work for, have had bad rear bushings.
DiscoEiner
Sep 21, 2014 02:37 PM
dougn
Oct 30, 2013 08:17 PM
appletree
Sep 3, 2013 07:31 PM
hampshier32000
May 10, 2011 11:54 AM
DiscoMike2003
Nov 13, 2008 04:57 PM
