Sponsored by: CARiD
Cruise Control not working
Old Jul 28, 2009 | 08:41 PM
csn4646's Avatar
Default Cruise Control not working
I have a 1997 Land Rover Disco series I. The cruise control used to work fine but one day it stopped working. When I click the button the light won't illuminate. I checked the fuses and they are fine. Any help or suggestions would be greatly appreciated. Thanks
Old Aug 4, 2009 | 12:13 AM
CANAMDiscovery's Avatar
I had an issue with my Discovery 1 that was similar...For me it was the vaccum lines had split at the plastic T joint under the hood....If it is the case...easy fix.
B
Old Aug 4, 2009 | 12:35 PM
genroxbro's Avatar
the pdf icon might not work if your home machine is not installed with a later version of adobe reader.To delete the pdf icon in the front end. i.e to hide the pdf icon for a particular article in the front end:login through the admingo to the articlenow select parameters advanced and set pdf icon to hidethen the pdf icon will disappear at the front end.hope this helpsregards,micky _____________________________________Website I designed for faxless payday loan canada company.
Old Aug 4, 2009 | 12:46 PM
roving patrol's Avatar
B
Where is the plastic t joint located at under the hood? I am having the same problem!
tnx
Old Aug 5, 2009 | 06:14 AM
On my truck the vaccum line entered the engine compartment from right in front of the steering wheel...I would expect yours would be the same. The plastic T was not far from there. If I recall, one line runs to the front of the engine compartment, the other runs to the top of the motor itself. Should be able to trace it down. B
Old Aug 28, 2009 | 06:26 PM
a2tz's Avatar
I'm actually having the same problem.....all my vacuum line is cracked. I know where the...actuator is on top of the engine by the throttle, and see the line going in to the firewall, but the 3rd end is just loose under the jack. What does it actually connect to? And i guess i would like to know what it also connects to on the other side of the firewall. Thanks.
Old Aug 28, 2009 | 09:16 PM
a2tz's Avatar
ok so i sorta figured it out. got new vacuum tubing, found the thing under the jack...it has 2 nipples though. one white that has a big tip, and a small black one that it seemed to fit on better. hooked it all up....and it didn't work. my cruise light comes on though.
guess i'm gonna have to do some more research.
Carlton1
Jul 25, 2012 07:51 AM
fire57dan
Jan 16, 2010 06:27 PM
2K Disco II
Aug 11, 2008 10:42 AM
cosmiccharlie79
Jun 16, 2008 09:13 AM
bklahl
Aug 29, 2007 11:20 AM
