D1 sunroof
D1 sunroof
pulled the headliner tubes are cleared poured water through them no leaks and no backup cleaned around sunroof tracks oiled and so on but they are still leaking i was re tracing my steps of the past couple of months,,,,,,,,, i added the rovertyme 2 inch lift the front sits about 1/2 inch higher is this causing the rain not to drain ,,,,, i give up
My '99 Series II leaks at the joint between the roof and the entire sunroof unit. Found it by dropping the headliner and placing a slow running hose at various locations. Duck taped it for immediate fix and went looking for replacement seals. No factory items available unless you replace the entire unit (expensive). Heard there was a guy in England that used to make them but stopped. I have replaced the ducktape twice now as it wears out, with no body/paint damage. Still looking for a cheap solution.
