Sponsored by: CARiD
D1 sunroof
Old May 26, 2009 | 04:54 PM
DDP's Avatar
DDP
Default D1 sunroof
pulled the headliner tubes are cleared poured water through them no leaks and no backup cleaned around sunroof tracks oiled and so on but they are still leaking i was re tracing my steps of the past couple of months,,,,,,,,, i added the rovertyme 2 inch lift the front sits about 1/2 inch higher is this causing the rain not to drain ,,,,, i give up
Old Jun 5, 2009 | 03:33 PM
michar911's Avatar
3rd Gear
My '99 Series II leaks at the joint between the roof and the entire sunroof unit. Found it by dropping the headliner and placing a slow running hose at various locations. Duck taped it for immediate fix and went looking for replacement seals. No factory items available unless you replace the entire unit (expensive). Heard there was a guy in England that used to make them but stopped. I have replaced the ducktape twice now as it wears out, with no body/paint damage. Still looking for a cheap solution.
Old Jun 5, 2009 | 05:52 PM
DDP's Avatar
DDP
I removed the seal then found a similar sel used on bobcat loader doors modified and used black rtv sealant we had a major rain yesterday no leaks,,,,,,
BigRed98
Jun 21, 2010 12:30 AM
opus13
May 18, 2006 05:07 AM
Durfee
May 11, 2006 04:50 PM
Jesse
Mar 2, 2006 01:53 PM
funkeruski
Aug 22, 2005 02:26 PM
