Diagnose coolant leak
Re: 2001 Disco II, 155k miles
The vehicle has a minor coolant leak that seems to be coming from the point where one of the hoses is connected to the reservoir (see photos). I've searched all over the engine and radiator for the source of the leak but the only thing I've been able to see is the actual liquid coming out right after the vehicle is driven and the engine is turned off.
The splatter pattern seems to be all over the place, but the hose winds down to a point right above the metal frame where the frame angles down on both sides, so the coolant travels along the frame and drips at several points.
1. Is this likely to be source of the leak? (the hose connected to the reservoir)
2. Or is this a symptom of something worse?
3. If the leak is coming from the hose, should it be entirely replaced? Or can the end be spliced off?
4. Is there anything special about this hose?
5. Or can you suggest something else?
thanks
Carl
thanks
Carl
how much was the total cost of replacement? did you pay for the auto repair troubleshooting or just the parts and labor? My head gasket needs replacement and I'm thinking if it doesn't cost that much ill bring it to a garage.
The part was only the reservoir. I brought my own coolant. The labor included installation and pressure test.
C
ZMonet
06-24-2016 04:00 PM
