Sponsored by: CARiD
DII : How to remove door glass
Old Nov 27, 2014 | 12:12 PM
GLR's Avatar
GLR
4th Gear
Default DII : How to remove door glass
OK I'm a handy guy but everything is trial and error for me these days so I am going to ask if anyone can give me the proper procedure to remove the drivers / passenger door glass. I imagine the outer/inner seals need to come off and I need to unbolt the tracks at the bottom but that is where my observation ends.... I guess the glass would need to be rotated sideways to come out. Any pointers would be appreciated.
EDIT - I check the user manual, and a RAVE CD was in there! SO there is all the info I need on that... Mirrors need to come off too apparently.
Old Dec 17, 2014 | 01:40 AM
chas.grant.cg@gmail.com's Avatar
I took mine off today. If you need to take off your mirrors do not try it without looking at the videos first. Itll be easier for you to accomplish while watching the video than me explaining it.
Old Dec 17, 2014 | 10:14 PM
abran's Avatar
When you go to remove the window frame you should mark the exact position with a paint pen. This will make sure you get the frame at the right position to eliminate wind noise.
I remove the inner and outer door to window frame horizontal rubber/felt trim pieces and mark on the window frame with a paint pen. Then start loosening bolts.
Nothing worse then fixing an issue and creating another one!
ngarover
May 12, 2021 09:00 AM
SuperiorCarCare
Detailing
Feb 5, 2014 02:00 PM
wheelgarage
Oct 1, 2011 03:12 PM
SC Rover
Apr 26, 2010 01:00 PM
caleb
Jan 6, 2010 11:26 AM
