Sponsored by: CARiD
DISCO I - ABS - HELP
Old May 13, 2007 | 10:14 AM
mikeathome's Avatar
Default DISCO I - ABS - HELP
Hi,
exchanged two Front Wheel Speed Sensors yesterday. One was broken. Yellow dashboard 'Lock' icon still stays on.
Where is the ABS Main Control Unit Located? Where are the Rear Wheel Sensor Plugs hidden? Can you post a pic, or is it obviuos. Would it be possible that the main unit is broken caused by the worn wheel speed sensor? What to test?
Thanks,
mike
Old May 13, 2007 | 10:44 AM
Bill E's Avatar
Default RE: DISCO I - ABS - HELP
I haven't a Disco but you might look here to download a Rave Manual - Should provide some clues to help.
http://green-oval.com/joomla/index.p...&Itemid=29
Good luck.
Old May 14, 2007 | 03:48 PM
mikeathome's Avatar
ORIGINAL: Bill E
Good luck.
THANKS a lot, man!!!
mike
Malafax_Dand
Mar 30, 2009 06:31 PM
dammad
Jan 26, 2009 01:50 PM
cottonpatchweims
Feb 10, 2005 07:18 PM
cottonpatchweims
Jan 14, 2005 01:59 AM
