DISCO II BACKDOOR STUCK
RE: DISCO II BACKDOOR STUCK
The actual latch under the cover is metal, So yeah.. Road salt may have caused it to rust. You can use a screw driver to pry the latch back into normal position then pray it with WD-40 or something, Work the latch back and forth a few times and it should loosen it up.
