Sponsored by: CARiD
DISCO II BACKDOOR STUCK
Old Jan 13, 2009 | 02:02 PM
van1's Avatar
6th Gear
Default DISCO II BACKDOOR STUCK
I CANT OPEN THE BACKDOOR OF MY 2001 DISCO. POWERLOCKS WONT HELP OR MANUAL HANDLE IS ALSO STUCK. DO I REMOVE THE BACKDOOR PANEL? IS AN ACTUATOR BACK THERE? MOM CANT GET THE GROCERIES! ALSO NEED AFFORDABLE LR GUY INTHE LOS ANGELES AREA TO WORK ON DISCO. 661-476-2555
Old Jan 13, 2009 | 02:20 PM
Tedb's Avatar
Default RE: DISCO II BACKDOOR STUCK
Take the emblem out with a screw driver and spray the parts with penetrating oil....that should free up the mechanism.
Old Jan 13, 2009 | 03:57 PM
van1's Avatar
6th Gear
THANKS, I WILL TRY IT AND SEE WHAT HAPPENS. THEY TRUCK USED TO BE IN N.W. OHIO ROAD SALT MECCA.
Old Jan 14, 2009 | 11:42 AM
Rover Rob's Avatar
The actual latch under the cover is metal, So yeah.. Road salt may have caused it to rust. You can use a screw driver to pry the latch back into normal position then pray it with WD-40 or something, Work the latch back and forth a few times and it should loosen it up.
HawesEA2
Dec 17, 2016 09:47 AM
ImQuattro
May 1, 2014 08:36 PM
Scope
May 2, 2013 03:54 PM
boom_r6
May 27, 2010 08:35 PM
smyevich
Aug 31, 2006 01:31 PM
