Sponsored by: CARiD
Disco II engine question
Old Dec 2, 2009 | 04:43 PM
Gordon Bombay's Avatar
Default Disco II engine question
basically, i can't afford to put a 4.6 back in my 2003 disco. so my question is... can i put an engine out of a 99-02 in it? because they're much easier on the wallet
Old Dec 2, 2009 | 05:44 PM
What sort of prices are you seeing on a 4.6 short block, what happened to your engine?
By the way, yes you can but it will greatly lower the value of the vehicle.
Old Dec 3, 2009 | 11:57 AM
im not 100% sure that i will need an engine yet but it blew the head gasket on the driver's side in the back next to the firewall where the #7 cylinder is and i know that its the most common to lift. im getting ready to pull the head off and check everything out. hopefully i will just need the gasket kit and some machine work on the heads though
Old Dec 3, 2009 | 12:35 PM
Do you have large amounts of coolant in the crank case, if not, you'll most likely not have dropped a sleeve and gaskets and a little head work should be all you'll need.
Old Dec 10, 2009 | 04:04 PM
closumcub's Avatar
Default Re: please check my site
Thanks for the suggestion, I wish it had worked.
Bryan H
Jul 7, 2010 08:29 PM
Srgroovealot
Apr 6, 2010 10:29 AM
Eulogio
Jan 21, 2008 04:17 PM
tcbinaflash
Jan 8, 2008 04:23 PM
miishmiish
Mar 8, 2006 12:31 AM
