Sponsored by: CARiD
Discovery 3 problem
Old Apr 16, 2011 | 06:08 PM
DanielIsr's Avatar
Default Discovery 3 problem
Hello all
I own a Discovery 3 SE 2005, recently I have encounterd a problem that is repeating itself from time to time, unfortunatly the service garage haven't been able to discover the cause of the problem.
The problem is while driving at 60mph (100kmph) the rpm suddenley drops to minimum and the gas pedal does not respond.
When I stop and switch the engine off and start it again the problem disappears, or if I switch the gear to N for a few seconds and switch back to D the problem also disappears , but the cruise control will not work until I switch the engine off.
When the garage connected the car to the computer they did not find any problem.
Has anyone encountered this problem before? Does anyone know what the origin of the problem is or how to fix it?
Thank you
Danny.
Old Apr 16, 2011 | 08:07 PM
I believe that the throttle is electronic and the gas pedal is not directly connected to the throttle.
It is a "fly by wire" system, meaning there is no throttle cable.
So there is a problem with the throttle position sensor, the resistor at the gas pedal or a computer problem.
Old Apr 17, 2011 | 11:51 AM
DanielIsr's Avatar
Thank you
I hope that your answer will help me to fix the problem.
Old Apr 17, 2011 | 01:30 PM
PLEASE let us know when you get it figured out and what the problem was.
Old Apr 18, 2011 | 01:57 PM
Rovin4life's Avatar
clean the throttle with some brake clean but don't overdue it. Same reason why you get a p101.
Rover Rog
Nov 6, 2013 01:42 PM
Fredzzz
Oct 11, 2013 11:39 AM
XxRoverAllOverxX
Mar 23, 2012 04:49 AM
