Discovery II Intermittent trouble Starting Immobilizer?
I have a 2000 Disco II 4.0 which will
-will not start 30 min to an hour after parking when engine is both hot and cold
-will randomly randomly cut out when in Park
-Problem occurred within a week and seem to be gradually more frequent.
Everything seems to be fine
-Runs great
-FOB key locks and unlocks doors
-no blown fuses or trouble codes.
-Engine cranks over
-Except fuel pressure and spark which were both absent during the episode
I have read forms about Pre 99 Discovery having the same symptoms due to problems with the Spider/ engine immobilizer unit however the Disco II has a BeCM which controls the engine immobilizer/alarm. The only lead I have found is that the BeCM may need to re-sync with the ECU. But it starts sometimes and sometimes not?? Any have any possible leads or fixes? Am I on the right track thinking its the BeCM/immobilizer?
-Cheers
-Runs great
-Engine cranks over
-Cheers
jmconnelly5
03-09-2014 03:59 PM
Roverman7
05-15-2013 12:43 PM
baysiderover
10-06-2006 06:58 PM
2000, 99, discovery, engine, ii, immobilizer, immobolizer, intermitten, intermittent, key, land, problems, rover, starting, starts
