Sponsored by: CARiD
discovey fuel pump question
Old Jul 7, 2010 | 04:16 PM
christians1600's Avatar
Default discovey fuel pump question
1996 discovery ..just replaced the fuel pump a month ago (aftermarket) and now everyonce in a while with a 1/4 tank of gas the disco stalls and wont start until after 5 minutes and then it runs fine, no wierd idle or anything ..is this the throttle control sensor
or did i do something wrong with the fuel pump?? thanks..........
Old Jul 8, 2010 | 05:15 AM
Rovin4life's Avatar
change the filter. if that doesn't cure the intermittent stall then try to recreate it and diagnose it from there. It could be anything. improper set up on the fuel pump. kinked line inside the pump.
Old Jul 8, 2010 | 07:50 AM
Default filter
thanks i had already changed the filter and hoses r new and not kinked..so if the car stalls and wont start again for 5 minutes and then runs fine would this be the throttle sensor?? thanks..also its about 95 degrees here.......
Old Jul 9, 2010 | 05:53 AM
Rovin4life's Avatar
I cant tell until I put a fuel pressure guage on it and the like. Their are other reasons like a bad multifunction unit near the ECU or it could be the ECU itself is fried. Lots of reasons. Need to diagnose.
Travelor
Sep 24, 2015 06:11 PM
JumPeR04
Apr 7, 2011 09:52 PM
mydisco03
Jan 11, 2010 02:21 PM
dieselgeek
Jan 19, 2009 07:41 AM
ajusaf
Feb 21, 2008 09:21 AM
