Sponsored by: CARiD
Dissapointing head gasket job
Old Jul 7, 2011 | 04:59 PM
haleyrover's Avatar
oil was straight coolant .... something went horribly wrong. UGH
Old Jul 7, 2011 | 06:11 PM
Chris-bob's Avatar
Too much beer...?
Intake gasket not right?
Old Jul 7, 2011 | 07:43 PM
haleyrover's Avatar
there's oil on the intake gasket. is that a clue? and ... no such thing as too much beer. well ... when not taking an engine apart
Old Jul 8, 2011 | 10:47 PM
honda50r's Avatar
Dang dude, that is disappointing. I hope it gets well.
Old Jul 9, 2011 | 04:58 AM
drowssap's Avatar
have you pulled the intake back off yet? if not you may want to borrow a preasure tester fron autozone/advanced and preasurize the system to see were the coolent is leaking from if it is on top of the intake gasket. also did you put the pushrods in before or after the intake gasket?
Old Jul 9, 2011 | 08:30 AM
haleyrover's Avatar
I've pulled it off. There was some oil on the gasket. I installed the push rods before I put the intake on. Is that bad?
Old Jul 9, 2011 | 08:48 AM
Rovin4life's Avatar
what was the torque specs you used for the heads and what was the sequence you used?
Old Jul 9, 2011 | 08:55 AM
Also, did you use new head bolts?
Old Jul 10, 2011 | 08:56 AM
haleyrover's Avatar
I used new bolts and torqued in order according to RAVE. Was pretty **** about that. What I did notice when I took it all apart again is that the back right of the valley gasket was covered with coolant and that's where I saw the "milky" oil when I took the valley gasket off. I'm thinking I screwed up the seal on the valley gasket when I put the upper on. Would that make sense?
'04 Disco II (in pieces)
74k
Old Jul 10, 2011 | 09:05 AM
If and when you throw in the towel, send me your number and lets talk about what to check.
