Sponsored by: CARiD
Dissapointing head gasket job
Old Jul 11, 2011 | 05:02 PM
  #21
haleyrover's Avatar
Gonna try it one more time before I give up. Its all apart again.
Old Jul 11, 2011 | 05:51 PM
  #22
Chris-bob's Avatar
That sucks. But a gasket is much easier than a block. Just go slow and keep an eye on it this time around. Good luck!
Old Aug 1, 2011 | 06:30 PM
  #23
haleyrover's Avatar
Default what next
OK ... like a surgeon i did the head gasket job over again. Thinking my first time I screwed it up. Well, t runs better than before with new plugs and wires. Problem is there is still coolant in the oil !!!! guessing cylinder crack or something I could never see. Thoughts?
Old Aug 2, 2011 | 05:17 AM
  #24
drowssap's Avatar
maybe a preasure tester and a bore scope? pull all the plugs, preasurize the system while looking in each cylinder with the bore scope for signs of cooling.
Old Aug 15, 2011 | 04:38 PM
  #25
haleyrover's Avatar
Default I did it
My wife was reviewing posts before we gave up and found a post about front gasket leaks. I pulled that off and Voila! blown in two places leaking straight into the oil. Put about 50 miles on it and running better than ever. The oil light is coming on at low RPMs ... but I'm not scared now. Any thoughts?
04 Disco II 74 k miles
new Head gaskets, wires, plugs, water pump gasket, oil pan gasket, timing cover gasket.
Old Aug 15, 2011 | 09:20 PM
  #26
Oh, I would be scared. That light comes on at about 7 PSI. Stop driving until you can do a mechanical oil pressure test cold engine and warm engine. May be time for an oil pump, or something exotic like the oil pickup is loose inside the pan. And 5Wanything is too thin for summer.
Old Aug 16, 2011 | 10:15 AM
  #27
Chris-bob's Avatar
What oil did you use? If you haven't already, try rotella 15w-40 or a 20w-50 oil. See if the light goes away.
Old Aug 17, 2011 | 12:59 AM
  #28
speedstick345's Avatar
Have you found the root of the problem?
Conduct a compression test and all reading should be the similar
Check for spark and fuel pressure
Check the chamber did coolant seep in?
Old Aug 19, 2011 | 03:57 PM
  #29
haleyrover's Avatar
Thanks for the ideas. Now the a/c is out so my weekend is shot!
FlyingZebra34
Apr 25, 2013 08:04 AM
lipadj46
Jun 19, 2009 08:23 PM
01 Discovery SD
Mar 1, 2009 12:11 AM
Darover
Oct 17, 2007 02:50 PM
fsufan8
Aug 5, 2005 03:48 PM
