Sponsored by: CARiD
Drain cooliant completely from engine block
Old Jan 13, 2010 | 10:51 AM
yourbr.com's Avatar
4wd High
Default Drain cooliant completely from engine block
I need to know how to drain all the fluid out of the engine block. Please let me know if the hose that attaches to the water pump is the lowest point to let the coolant drain out completely or if there is a plug that I need to remove in the engine block.
I have a '97 Discovery I. 192,000.
I am burning radiator fluid. White smoke out of tail pipe. I am going to put a block/ gasket sealing liquid in the coolant system hopefully to buy me a little more time.
Old Jan 13, 2010 | 12:33 PM
Who's product are you planning on using, is it on that has a lot of some type of metal shavings in it, is so don't use it.
As for drain the system, pull the pet-**** on the bottom of the radiator.
Old Jan 14, 2010 | 03:11 AM
yourbr.com's Avatar
4wd High
Default Coolant draining
There is no petcock at the bottom of the radiator. The only way to drain it is to take the bottom passenger side hose off. It does not completely drain the radiator tho.
Is there a way of draining the engine block also. Where would the lowest point on the engine where the block can be drained? The product has some type of glass in it that hardens when left in when it dries.
Old Jan 14, 2010 | 09:54 AM
yourbr.com's Avatar
4wd High
I am using a product from K&W Nanotechnology called Permanent Head Gasket & Block Repair. I hope this will work to seal up the crack or head gasket leakage.
What do you think about this product? It has Sodium Silicates, Water, Copper flake and Aluminum paste.
Old Jun 18, 2010 | 06:42 PM
jkeving's Avatar
I have an '03 and '04 Disco. The '03 has had the dreaded cylinder 6 coolant leak. I used the K&W product and got 38k miles on the repair. Unfortunately, I now have #4 cylinder coolant issues and will try again. The coolant must be completely clear (Grey Goose Vodka clear) for it to work. The product will not fix the valley pan gasket leak (that was the '04 truck
Old Jun 19, 2010 | 06:29 PM
Rovin4life's Avatar
had a guy that used the mineral stuff. Turned the radiator to a block of minerals and the small lines filled up and snapped. And after cleaning it the radiator was still leaking as was the head gaskets.
sadain
May 3, 2012 09:40 PM
oysterhead
Aug 29, 2009 11:09 PM
wadematt
Apr 19, 2008 09:05 AM
GregHaugen
Feb 23, 2007 06:42 PM
