Sponsored by: CARiD
EAS stuck in highway mode
Old May 15, 2008 | 01:44 PM
bhorwhat's Avatar
Default EAS stuck in highway mode
My 03 RR has the EAS stuck in highway mode. The inhibitor light is stuck 'on', ie it won't go off when pressed. Therefore, you can't lower or raise the car.
Compressor is working.
No faults showing
Any ideas or suggestions would be appreciated.
Old May 15, 2008 | 01:46 PM
WolfPack's Avatar
Default RE: EAS stuck in highway mode
Bad switch throw maybe? The switch just isn't being affected by the movement of the button! Could be a wire issue....oorrrr maybe a height sensor...hrm..
Old Aug 12, 2008 | 02:36 PM
bhorwhat's Avatar
Dealer says its the compressor and some valve. Long story short, $1300.
Old Aug 12, 2008 | 04:39 PM
WolfPack's Avatar
Stop and check your options. you can buy a reconditioned compressor for a couple hundred, and a new valve body for not much more. Pretty easy to put in yourself. Also you can look into a complete spring conversion...not sure if there is a kit for mk IIIs, but that's the same boat I was in with my '01. I had 2 blown bags in the rear, $2100 to fix, or $1800 to convert to coils.
angasreid
Dec 16, 2023 07:45 AM
ImQuattro
May 1, 2014 08:36 PM
cmossman
Jul 19, 2010 03:06 PM
leddifer
Feb 25, 2010 07:52 AM
yarddawg
Dec 10, 2007 05:19 PM
