Sponsored by: CARiD
electric rear window problems
Old 05-03-2009 | 04:19 PM
rknuts67's Avatar
Default electric rear window problems
I own a 1998 Landrover Discovery and the rear electric windows will not work. The front electric windows do work. Both front and rear window fuses are ok. Also the rear window motors test ok. I checked the rear window isolation switch and it works properly. THERE IS NO CURRENT PRESENT at the rear window switch connectors on the console. Can there be something partically wrong with the window electonic control unit (ECU) even though the front windows work? A new ECU will cost $100 and I do not want to replace it if I am dead wrong. HELP
Old 05-04-2009 | 06:45 AM
antichrist's Avatar
You could always convert them to manual and not worry about them any more. That's what I'm doing with all my windows.
Old 05-04-2009 | 09:17 AM
You most likely have a cracked or damaged circuit board in the body ecu that is causing this, kind of common, usually it can be repaired.
daniep
12-30-2013 02:26 PM
alemurill
05-08-2009 01:28 AM
johnboyairey
10-16-2008 06:16 PM
brian.arthur
Freelander
11-30-2007 06:45 PM
BrianH
07-13-2005 02:37 AM
