Sponsored by: CARiD
electric rear window problems
Old May 3, 2009 | 03:19 PM
rknuts67's Avatar
Default electric rear window problems
I own a 1998 Landrover Discovery and the rear electric windows will not work. The front electric windows do work. Both front and rear window fuses are ok. Also the rear window motors test ok. I checked the rear window isolation switch and it works properly. THERE IS NO CURRENT PRESENT at the rear window switch connectors on the console. Can there be something partically wrong with the window electonic control unit (ECU) even though the front windows work? A new ECU will cost $100 and I do not want to replace it if I am dead wrong. HELP
Old May 4, 2009 | 05:45 AM
antichrist's Avatar
You could always convert them to manual and not worry about them any more. That's what I'm doing with all my windows.
Old May 4, 2009 | 08:17 AM
You most likely have a cracked or damaged circuit board in the body ecu that is causing this, kind of common, usually it can be repaired.
daniep
Dec 30, 2013 01:26 PM
alemurill
May 8, 2009 12:28 AM
johnboyairey
Oct 16, 2008 05:16 PM
brian.arthur
Freelander
Nov 30, 2007 05:45 PM
BrianH
Jul 13, 2005 01:37 AM
