Sponsored by: CARiD
Engine System Fault - Special Programs Off
Old Oct 20, 2022 | 06:50 AM
L7UTD's Avatar
Default Same Problem
Originally Posted by fhollo
These problems are caused by a split hose that goes to the turbo causing it to lose power or can be loose connectors in the Terrain Control module. Or also if yr battery is weak and has lose terminals.
hope one of this may solve yr issues.
cheers
Hi All, New to the forum, but i thank you for your help, i had the very same problem, with the thought of a very large repair bill i took to the internet.
At the same point on my daily commute the car would drop into limp mod with ESF Special Programs Off.
Having not long had a new Battery i first check the Two hoses to the turbos and 1 had a large split in. Changed it that day (2 weeks ago) and pleased to report I've not had the problem since. So again thank you!
Luke (2010 RR Sport TDV8)
Old Oct 26, 2022 | 10:11 AM
harrydarwen's Avatar
Engine message with no loss of power and special programmes with a loss of power. I have just my egrs replaced. My turbo had seized but the garage freed it up, but I’m guessing maybe the turbo!
boldguard79
Apr 18, 2018 02:20 PM
tugbeh720
LR2
Aug 11, 2017 12:28 PM
06Range
May 8, 2013 09:01 PM
hournet562
Feb 4, 2011 04:28 PM
bartjjansen
Aug 20, 2010 05:41 PM
