Sponsored by: CARiD
engine wont turn over
Old Oct 20, 2014 | 06:38 AM
machinetech's Avatar
Default engine wont turn over
97 discovery was working fine. Son came over to redo the seats was using the radio in the truck and got worried he was running battery down so put charger on it till he was done. Went to start truck and it doesnt do nothing. I checked the battery and it reads 14 volts. any ideas where to go next will be appreciated.
Old Oct 20, 2014 | 08:41 AM
abran's Avatar
Are the cable connections solid? If so, try cleaning all the connections including ground at the body/frame.
Old Oct 21, 2014 | 06:20 AM
Default engine start problem
Cleaned all ground terminals. Still not working. Did notice that instrument cluster does not light up on position 2 and clock light is not working. also did notice that radio loses power when trying to start. Any help will be appreciated.
Old Oct 21, 2014 | 03:16 PM
abran's Avatar
Check the positive (red)connection to the starter and the ground(black) cable from starter to frame/body.
Old Oct 27, 2014 | 06:25 AM
Default still starting problem
Put all new cables and ground wires along with new starter I had here. Turn key and acts like something shorting out. Any ideas what to do next will be appreciated. Thanks so far for all your help.
Old Oct 27, 2014 | 07:11 AM
abran's Avatar
I'm stumped. Try posting in the discovery 1 section, there are a few electrical wizards there that can probably help.
Did your son do any mods to the electrical when working on the seats?
Old Oct 27, 2014 | 01:28 PM
Default update
Son just put new covers on seats, didnt have to take them out. will repost
Old Oct 31, 2014 | 09:39 AM
Smile update on no start
Found igniton switch went bad. Replaced and truck started right up. Thanks for all your help/
ssrover
Apr 19, 2015 08:13 PM
SolbergFanBoi
Mar 5, 2012 07:05 PM
cbritt
Oct 13, 2009 07:23 AM
cellman01
Jul 28, 2009 06:44 PM
tryinthis2
May 22, 2008 09:35 AM
