Sponsored by: CARiD
A few Maintenance Questions
Old Jul 18, 2007 | 10:13 AM
Red Devil's Avatar
3rd Gear
Default A few Maintenance Questions
I'm from the US and I have a 2002 Freelander V6(gas, not diesel). I'm very handy when in comes to cars(Built 2 race Mustangs) but this thing has me baffled!
The owner's manual is basically useless
1. How do you check the transmission fluid level? Where do you add it?
2. What transmission fluid do you use? The dealership didn't even know.
3. What spark plugs to use? What should they be gapped at? Standard, not metric.
4. I have BF Goodrich A/Ts on the car and they need to be rotated.
-Should I go, left front to left rear. right front to right rear. and then left rear to front right. then right rear to left front?
Also, while backing up in an underground parking lot, the wife snapped off the antenna. base is still attatched but the rest snapped off. where can I get one?
Thanks all for your help
Old Jul 18, 2007 | 12:08 PM
Default RE: A few Maintenance Questions
Do you have an owners manual, if so it should have some answers for your questions.
As for the ATF, you can only use Rovers ATF or you will fry the tranny.
As for the spark plugs, pull an old one, that is the easy way to see what the factory plug was.
As for tire rotation, you should do it every 7500 miles.
Mike
TheWhiteRover
Jan 24, 2014 05:53 PM
SoCal Rob
Nov 4, 2013 03:16 PM
seamuspg
Sep 18, 2009 06:55 PM
sharp
Feb 3, 2009 09:27 AM
IXLR8RVR
Dec 7, 2004 02:14 PM
