Sponsored by: CARiD
gear shifting problem in my 98 discovery
Old Dec 19, 2011 | 08:06 PM
tom123's Avatar
3rd Gear
Default gear shifting problem in my 98 discovery
I have a 98 discovery with 99k miles on it and when I took it offroading and got it wet it doesn't shift properly. it has to dry and slowly fix itself before it can shift out of first gear. why is this? any help is appreciated thanks
Old Dec 19, 2011 | 08:12 PM
Unless you got water into the transmission getting it wet has nothing to do with it.
Have you checked the transmission fluid level?
Truck on level ground, engine idling, trans in park.
Pull dipstick, should be above the "low" mark.
Old Jan 1, 2012 | 05:08 PM
RezzaHD's Avatar
On my land rover I have a shifting problem as well. Mine Is a 97 Disco and I have to let off of the gas pedal sometimes to get it to shift into the next gear. The trans fluid has never been changed and since it hasn't I have been told not to change it.
Old Jan 1, 2012 | 05:17 PM
Not having ever changed it also means filter will be clogged. IMHO you should locate an indy shop that does the BG 44 transmission fluid flush (or another high quality product). This can flush out a lot of the old gunk in the tranny that a regular change at this point would simply break loose (to clog filter and cause more problems). see BG Findashop - Search for an authorized BG service center near you!
Old Jan 1, 2012 | 06:30 PM
That is a total load of BS, the whole reason you are having trans problems is because the fluid has never been changed.
Have the fluid and filter changed and then have a trans power flush done.
It is a old wive's tale to never change the fluid in a old transmission, would you never change the engine oil because you went over due on the last one?
it is your truck, have it changed, if they wont do it tell them you do not want a warranty, you just want the work done.
Old Jan 2, 2012 | 07:25 PM
tom123's Avatar
3rd Gear
alright thanks a lot I appreciate the help. if it is not the transmission fluid, is it possible that the carburetor is getting wet? because once it dries it runs fine
Old Jan 2, 2012 | 07:39 PM
Um, it is fuel injected, no carb.
Old Jan 3, 2012 | 07:20 PM
tom123's Avatar
3rd Gear
alright thanks I appreciate the help
baghdadi
Jan 18, 2015 02:23 AM
archaeology_student
Sep 8, 2014 08:07 AM
kristoffersmith
Aug 13, 2013 04:40 AM
stu44mag
Dec 2, 2010 10:11 AM
Bivwak2000
Jul 7, 2008 01:09 PM
