Sponsored by: CARiD
gems to bosch block
Old Oct 21, 2013 | 01:56 PM
gah964's Avatar
And there should be one missing tab for sync.
yes I have the flywheel out no way they are the same the tab gap don't even line up and the ring gear teeth trashed my starter errrrrrrrrrrrr damn that ebay compatibility chart errrrrrrrrrrrrrr
Old Oct 21, 2013 | 02:29 PM
jafir's Avatar
Gems and Bosch engines should use the same starter. I wonder what happened.
Old Oct 21, 2013 | 04:13 PM
gah964's Avatar
I am not sure but I did hear the gear binding when I cranked the starter maybe that flywheel was bent not sure.i will investigate it more.I will turn the gems and bosch ring gears together and see what I get.
Old Oct 21, 2013 | 04:47 PM
gah964's Avatar
I checked and the ring gear teeth are the same but gems is 3mm thicker
so the teeth on the starter where only hitting the bosch ring gear 1/4" in.
I tested the starter it spins to slow.
David Kadasia
Jul 15, 2017 10:22 AM
BW_Hunter
May 24, 2012 01:56 PM
toad2
Aug 19, 2010 09:13 AM
garcia1000
Nov 24, 2009 10:30 AM
MOTERO5
Mar 26, 2009 10:30 PM
