Sponsored by: CARiD
hard to select gears n crunching
Old May 19, 2013 | 04:20 AM
Ann Dixon's Avatar
Angry hard to select gears n crunching
Hi i have a 300tdi and it would not go into any gears, Partner thought it was clutch so replaced that and also the flywheel housing as that was cracked.
Now the clutch and the housing is in, Went to try it today and it is doing the exact same thing. finding it hard to get in gears up or down and scrunching like mad. Went to check clutch cylinder tonight and checked the bell housing and flywheel housing ad both have cracked in the exact same place as before.
Any ideas would be gratefully thankful. Many thanks in advance
Old May 19, 2013 | 07:08 AM
A drain of fluid from the manual gear box may reveal metal pieces. While rebuild of the gearbox is possible, and the RAVE has documentation on this, a used trans from a breaker (salvage, junkyard, boneyard) or a dismantler (who specializes in Rovers) might be a faster approach. It is easier to replace a transmission as a unit than rebuild the innards. A used transmission near me is about $125 US.
Old May 19, 2013 | 08:32 AM
antichrist's Avatar
Are you saying both the flywheel housing and bell housing are caracked? That's very unusual. It's possible, I suppose, that there is a severe alignment issue. On the otherhand I've had bother motor mounts and gearbox mounts completely shot and not had the housings crack.
But incorrect alignment is all I can think of at the moment. I have gearboxes pretty much disentigrate and not cause the housings to crack.
Possibly the release lever is binding so severely it's causing the housing to crack. That would explain the grinding when trying to shift.
Please post the outcome.
TheBelly
Aug 10, 2008 04:39 PM
starcraft
Dec 5, 2007 04:08 PM
samsly
Nov 25, 2007 08:04 AM
nitim
Sep 16, 2007 09:36 PM
badbowtie85
Jun 18, 2007 11:28 AM
