Help. Disco II towed twice.
Hey guys,
I tried searching forever and found nothing.
I was driving my Disco a couple weeks ago and all of a sudden it died. I tried to start it and it would turn over but would not start. One of the relays in the engine bay fuse box was buzzing (the relay with the picture of an engine and a lightning bolt through it, I forget what its called). I pulled out the relay and disconnected the battery then called a tow truck.
The next day I walked out to it and popped the relay back in and hooked up the battery and it started up perfectly fine, and ran fine. I said ok and drove it 2 weeks and the samething happened again last night.
I have looked at all the wiring I can see in the engine bay. I even pulled the fuse box out and inspected the wiring. I may have missed something. Ive ran out of ideas and I refuse to drive it until I find it. Any help would be great.
-Kevin
-Kevin
Whoa - you said Cam Shaft sensor before - they are two different animals. Crank Position Sensor won't let you crank, or will stop you. The buzzing noise may be something else. See attached. If replacing, be sure to assemble same way it came off - bolts+spacer+sensor+block. Spacer does not go between unit and block.
